Have a Valliant EcoTec plus 637 system boiler that is showing no error codes and S.0 (no demand for heat), but it is not heating.
Have checked that it is receiving switched 240V heat demand into PCB, so believe it's a boiler issue.
Boiler was working fine up until needing to fix small leak in UFH manifold and swap over TRV rad valve. When boiler and heating system turned on again the boiler didn't respond to heat demand. Water pressure showing 1 bar on the LCD.
I noticed that water pressure was very low when I switched it off, to the point that I would have expected it to stop heating but it didn't.
Have tried resetting, power down and on. Have had a look at PCB and other than some spark discharge at the Ignition Transformer connection there are no obviously blown components.
It probably needs some pressure in the expansion vessel, but that wouldn't explain the S.0 code.
Is there a way to manually force it to heat, to try and isolate the problem?
My thinking is that if it is getting demand for heat but responding that no demand for heat then it may be PCB.
What else should I be thinking about?
