We have a Valliant Turbomax Pro 837e Boiler and while I appreciate it's not the most energy efficient of boilers, we bought it primarily for the stonking DHW flow rate, I am deeply concerned at the amount of gas we are using and the fact that it seems to struggle to do the job.
Our heating is turned 'on' all the time, although only required to bring our Bungalow to the living temperature of 21.5° for a couple of hours in the morning and a few hours in the evening. It maintains a temperature of 19° minimum outside these times. Our controller has an optimum heating function where it works out when it needs to turn the heating on to reach the desired temperature for the time you set and at the moment, for example, it turns the heating on at around 3.30-4.00pm to get from 19° to 21.5° by 6.00, which is doesn't quite do. It's usually around 6.30-7.00 before it gets to 21.5°.
I'd have thought it would be a breeze for this boiler. I know there are other factors to consider, but what I am wondering is whether it could be something in the setup of the boiler. How do these come settings-wise out of the box? Do they need much messing around? For the 4-week period from late November to late December, we used £100 of Gas, which I think is insane.
Incidentally, the bungalow is Cavity wall insulated and has loft insuation, although that could do with improving. We used more gas this year (actual quantity of gas) than the same period last year, even though last year we weren't cavity wall insulated.
How can I find a list of Valliant specialists in my area? I would like to get the boiler serviced (it's a few months overdue) and checked out.
