I'm sure one of you experts can help me sort this boiler problem. Simply because i have a second replacement boiler that i can take parts off to use to fix the faulty one.
Basically the boiler as the following problem. The hot water always works fine but the central heating is overheating. I have to watch the temp and switch off before it reaches a 100 degrees on the combi temp indicator.
I've had a few suggestions that it could be the overheat cut-out sensor but this really doesn't seem right to me as I thought this sensor triggered a cutout if it detected overheating and would require a manual reset (push button) to start the device up again. Which makes me think my problem is not caused by this sensor (Am i right?)
As mentioned above I have an old boiler which i can take parts off and am stuck as to what part to swap. Should i swap the main PCB board or just the Overheat cutout sensor or is it something else? For obvious reasons I don't want to swap both if i don't have to.
Also could it be the Room Thermo stat?
The boiler is a Valliant Combi VCW Sine 18 T3
Thanks in advance
Thanks in advance
