valliant ecomax 843/2e
23 Oct 2009
Bradford
hi wondered if any of you guys could help .
been to this boiler now 3 times i,ve changed the ntc's and the pcb because they were faulty
the problwm is the boiler lights as normal and you get hot water like you should but every now and again it sticks and you can't get either just alot of groaning from the boiler .
i,ve checked the bypass and thats clean and moves freely , the pump is working fine cos when it works all the rads get hot but still seems to get up to temp then cut out only does it on the heating side tho not on ths dhw
if you wait 10 mins turn it off then on again , bingo it works
and to make it just that little bit harder theres no fault codes yippee.
any ideas
any ideas....yup
try the plumbing forum :LOL: :LOL:
maybe some one from admin will move ur post over?
