Hi All,
I have a Vaillant Ecotec Plus 837 installed 5 months ago. The hot water works fine but all the radiators are only lukewarm even though I have set the thermostat to 35 degs and the flow temperature to 75 degs. I have checked each radiator and there is no air. The flow temperature does not seem to go above 36 degs in the first 15 minutes or so. I have set D.0 to 16 as my calculations of total radiator output is 16kw (13 radiators).
The boiler could take an hour before the flow temperature would reach somewhere around 50 degs, so it rises very slowly. The radiator symbol just constantly flashes.
When I press 2 buttons and activate something called 'Chinmey sweep', the radiators heats up within minutes.
Sometimes when I switch the boiler off and on again, it sometimes fires up instantly heating up the radiators to hot.
Is this in ecomode or something?
Any suggestions to what the problem could be?
