Valliant EcoTec Plus Boiler - High Pitched Whine
10 Dec 2007
London
Please can someone try and help me figure out what is causing this high pitched whining. I have tried bleeding and balancing the system but still no joy.
System:
Vailliant EcoTec Plus Combi Gas Boiler
5 x Hudevad radiators of varying size with thermostatic valves
Chrome towel rail in bathroom
Problem:
Boiler makes a high pitched whine, shortly after startup or whilst the heating is on, it is a consistent whine in sound and occurs pretty regularly.
The problem has only come about since i noticed the rads weren't getting hot in certain rooms, mainly the bathroom so i tried bleeding and balancing the system.
When bleeding I found no air pockets in any of the rads.
When i balanced the system the heating worked perfectly for about a week or so and then the whining started.
I have tried re-bleeding and balancing the system but it has made no difference.
I have tried different levels of pressure in the system but it makes no difference.
Two of the rads are cold at the bottom and hot to very hot at the top.
The system was only installed in Feb / March of this year as part of a house renovation. I don't know if the plumber flushed the old system as part of the install process. I would have hoped so, but I can't say for sure either way.
I have read on the forum that it could be a water lubricated bearing??? causing the whine. If so, is this something I can fix or do I need to get a plumber out. If so, no problem, just need to know either way.
With the rads, being cold at the bottom, is this caused by sludge?
I hope there is enough info here for someone to be able to suggest what might be the problem or what I can try as I am losing my patience with it and the whine noise is driving me mad.
Thanks in advance for any help and suggestions.
James
Its difficult for me to suggest anything without hearing your whine.
As its under the installers and the manufacturer's guarantee then why not call the installer back first?
Tony
how long is the guarantee?
i'll give Valliant a call.
i can't get hold of the original installer, he seems to have disappeared.
thanks.
2 years on everything, 5 years parts only on plate heat exchanger.
Vaillants number is on the sticker your installer has put in the drop down front panel.
Be wary though, if Vaillant come out and say there is no fault then they have the right to charge a call out.
How did you do the balancing?
Is the temperature difference the same for all rads?
Can you locate the origin of the whine more precisely?
Is it possible my ex is hiding in your boiler?
Balancing - turned off all the rads, started with the problem rad turned back on, worked my round to the rad closest to boiler.
Temperature difference - yes
Origin of whine - inside the boiler somewhere???
I called the Vaillant support line and the women said it sounded like the air pressure valve, but i wouldn't like to be quoted on that.
Your ex - possibly...
I have to give up here, do not even know how the air pressure valve works
Hi James,
having similar issue, did you find out what the problem was?
Many thanks in anticipation of a reply.
Kind Regards
Ian
