Hi I'm looking for a set of coals for a valor BR218B1 gas fire which is quite old I've tried everywhere I can think of . I know this fire is discontinued can anyone help ? Thanks for reading
You used to be able to buy bags of loose coals on fleabay, not sure if the Valor ones interlocked like a jigsaw, is the fire sealed with a glass front? if so you possibly can get away with odd sized coals, but be carefull if the burner is slightly blocked the fire can produce CO and if an open fire can obviously be v dangerous get a CO alarm
Cheers algas I've seen the one on ebay but would rather go with the right ones if possible I'm awaiting a response from valor thank you for helping cheers
