Valves for Heatline Capriz 28
10 Jan 2006
Merseyside
I have a Heatline Capriz 28 that has developed a very small drip from the hot water valve.
I have been told that these valves are sold as a set, i.e you have to buy all 6 valves and that the set costs approx £160!!!
Does anyone know a place that sells just the single valves - surely someone must've bought all six previously and only used one?
Cheers
Hi Think you are mistaken the hot water outlet should not have a valve on it, the valve should be on the cold water inlet, the hot water outlet should just be an elbow
you are right they only sell a pack of 5 the manufacturers part number is
D002160280, I would go into your nearest parts centre and ask the bloke in there to look up the pack and ask if he has a similar valve that they sell as a single I know the Vokera is very similar they are only valves as long as you get one with the same orientation it wont matter a jot who made it
just checked for you wolsley part number 479096 will do the job for you most parts centres will have them in stock retail is £23 but haggle and you should get one for half of that good luck
