Hi
I'm fitting a (central heating) heated towel rail and have been looking for suitable valves. However, almost all of them I have seen are 15mm, whereas the pipes to my existing radiator are 10mm.
Do I need to find (apparently rare) 10mm valves or is there such a thing as a 10mm-to-15mm coupler I could use to join the pipework? The pipework needs to be extended a bit anyway, so I could make the join below the floorboard to make the job neater. Also, I'm not wanting to do any soldering, so is it permissable to use push-fit or compression fittings for this purpose?
Thanks in advance
Dean
Thanks in advance
Dean
