I'm just starting to fit PIR board to a lean to roof. 100mm of board between the 150mm deep raters, and 50mm underneath.
I've read the Kingspan technical document and they recommend paying close attention to the detail where the roof meets walls and windows. Fair enough.
I have 100mm wide foil tape that I was going to use to form a continuous barrier between insulation boards on the final 50mm layer, but I'm wondering if I should also use it over the top of the first 100mm layer to seal the rafters in too?
Where the roof meets the wall, what should I do - Gripfill, silicone, or foil tape the PIR board on to the wall plate?
It's a tiny roof, but fairly complicated having a hip and two velux's in it. nearly every board has a triangular aspect to it so the initial 100mm layer isn't going in especially gap free.
Gary
Gary
