Hi I have built a single skin block shed and have decided to clad with upvc cladding rather than plaster it. Can anyone advise if I need to put in a vapour barrier between the block wall and the battens or is that overkill. If the answer is yes, would the green plastic sheeting sold on screwfix be sufficient or should I go for something of higher spec. Thanks in advance
