Hi I'm after advice on an insulation project I'm about to start. I've got an old mobile home with typical aluminum cladding then basic polystyrene boards between structural battens, then 2mm wood sheet walls. There is no vapour barrier fitted.
I'm planning on adding celotex boards to the inside using adhesive then cladding them with something like more 2mm wood sheets or maybe tung & groove.
Im thinking I will fit a heat recovery unit for fresh air in winter.
Am I going to have condensation issues or does the polystyrene act as a barrier?
TIA.
TIA.
