Vapour Control Barrier
31 May 2007
Hello again
A quick question regarding Vapour control barriers.
Existing walls are double skinned brick, no cavity no insulation, I plan to fix 3x2 battens insulate Between with 50mm celotex.
My question is regarding the VCL.
I read somewhere about taping up the edges of the celotex where it meets the edges of the battens to create a VCL like that.
Is this an accepted method?
If so what tape would I use.
If not acceptable, would I be placing the vcl over the battens or just over the insulation and taping.
If I do place the VCl over the battens then when I screw in my plasterboards won't that damage the vcl?
Many Thanks
Use foil tape for the inso' joints.
You could always use duplex plasterboards for belt and braces.
All vcl's get punctured one way or another.
