Hi
We are currently building a tiimber framed workshop.
The outer leaf is concrete block. Inner frame 150mm timber with mineral wool insulation with 9mm sterling board covered with breather paper.
Preformed trusses clad with sarking board, roofing felt then metal box profile sheeting.
Inside we are going to line the frame and the underside of the ceiling rafters with WBP plywood.
Would you recommend installing a vapour control layer directly behind the WBP, as I understand that WBP is moisture resistant thus preventing any moisture from passing through ?
All things considered would it hurt to include it ?
