Varnishing real wood floor
15 Nov 2004
I've just put in the bedrooms REALWOOD flooring rather than LAMINATE flooring.
To protect, I bought RONSEAL DIAMOND Varnish and on the tin it states..
NOT TO BE USED ON LAMINATE FLOORING.
1st point: Why not.
2nd point: Would REAL WOOD be the same as LAMINATE in this instance
Thanks in advance.
imo (may be wrong) the answer is in the name "real wood"
laminate is a layer (or several layers) so the varnish will not "soak in" on a laminate floor.
so real wood is real, not some reconstituted stuff
1st point: Why not.
1 and 2: Laminate flooring in the trade is the term used for Melamine Laminated Flooring. REAL WOOD in layers (with a top layer of solid wood) is also sometimes called laminate, but in order to prevent 'mistakes' we try to promote the name: Wood-Engineered flooring.
So you cannot use Ronseal varnish on a (Melamine) laminate floor, because it's a pre-finished product, you can use Ronseal varnish on an unfinished Wood-Engineered floor.
Hope this helps
Thanks most appreciated, what about if I lightly sand the new realwood floor before varnishing
That would get rid of greasy finger marks etc, but normally Wood-Engineered (unfinished) comes pre-sanded. (At least, ours does ;) )
You have the risk of creating sand mistakes which WILL show after you finish it with varnish/oil etc.
Thanks again
Im going to risk it and let you know (even post a picture here of finish)
Thanks very much, at least I now know what the risks are
