Vaulted ceiling with glazed gable end
26 Aug 2015
Hi all,
First time post so please be kind. I am planning an extension with a gable end facing the garden, and would like bi fold doors with a glazed gable above and vaulted ceilings internally.
I'd like to avoid ties but not sure where the ridge beam would bear on the glazed gable end due to the glass? Would this require a steel frame at the gable end? Or is there another method I have missed?
Can confirm dimensions later but for now assume 6m ridge length, 4.5m between wall plates and 25degree roof pitch with concrete double roman tiles. Traditional construction to side walls.
Many thanks
Ryan
I'm no designer but your idea sounds tricky. There may be a design that incorporates say two vertical steel columns with a cranked pair of steels (pitched the same as the gable/roof) that may be able to support the steel.
Your other headache is dealing with things at the head of the bi-folds and the glazed gable above. This may mean an additional horizontal beam forming say goal posts with the side columns. Viewed from the front it would look like a pair of columns with a triangle on top.
Get it designed and it shoud be possible, but under no circumstances do it without techy drawings in advance.
