My 2004 Vauxhall Combo van is on loan to some friends but they have been having problems with it. Fist it stopped charging the battery, now it won't start. Today I went to where it broke down to try and fix it. I have tried the following:
1) Check for 12 volts at the glow plugs
2) Check resistance of all 4 glow plugs
3) Crack open an injector pipe and check for fuel flow when turning starter
4) Partially drain fuel filter in case there is water inside
5) Disconnect air hose and check for intake suction.
6) Check for water in the oil
7) Check for oil in the water
I have not checked anything on the turbo as I know nothing at all about turbos. I suppose the next check might be compression. I have a tester but I'm not sure if it is suitable for diesels. It was raining most of the day so I could only work on it between showers. Any thoughts? I'm hoping we can tow it to my place for more thorough diagnostics.
