Have got 12 year old Vauxhall Astra Hatchback. Several weeks ago, fault first occurred. Turned ignition switch to start up but nothing happened, no noise from start motor, only silence. Tried to start the car a few times, eventually gave up. Got out of car and reached through window to remove ign. key and turned it for one last try. The starter turned and car started! Tried starting again from the driving seat and no response.
So got out and again turned the key while standing and again car started!
The car started normally following this and went all right for two or three weeks. But yesterday the problem returned. First time the same thing as above happened but then on the second occasion it would not start at all, (in the drivers seat or standing outside and turning ign. key). But when I left and returned to the car a couple of hours later it started first time! This has now become the norm. javascript:emoticon('') If the starter won't turn leave the car for an hour or so and it will start normally on return. Can anybody help with this, I cannot understand what could be causing it to behave in this way. It's puzzling!
