- Joined
- 18 Aug 2004
- Messages
- 5
- Reaction score
- 0
- Country
Time to "un-lurk" and seek the advice of the board instead of passively reading!
I have a problem with windscreen mist on my '96 Astra Estate (1600 petrol). I've merely "dealt with it" since I bought the car a couple of years ago, but driving down the M40 and suddenly going from clear screen to zero visibility in seconds has prompted some action.
I've had it happen a couple of times, always in the rain, and it happened for the second time on a quiet A road a week or so ago - I had to pull over and wait for it to clear. No amount of wiping would shift it. The inside of the windscreen was drenched - so were all the interior windows! Scary.
Window open - no change (except I got wetter!)
Heaters/blowers on full blast - nothing apart from a small clear area at the base of the screen.
With all the heavy rain of late, I decided on the previous occurence it may be a recurring problem, and ironically that "I wouldn't want it to happen on a motorway". So I did a bit of Googling and found that it is a common issue.
The information I found suggested that it might be a blockage in the outlet pipe for the drainage channel that runs under the windscreen. If this fills with water, the ventilation system apparently blows all this lovely water into the cabin.
So, before I set off on today's motorway journey, I located the pipe - a flattish, rubber pipe in the centre of the bulkhead at the back of the engine bay - and pulled out half-a-handful of black gunge.
I thought that would cure the problem, but it didn't. Driving along the motorway, luckily having slowed down due to torrential rain, the windscreen misted up in a matter of seconds again. Thankfully, I was close to some services and pulled off to wait for the rain to clear.
Has anyone else suffered this problem?
Has anyone tried any of those commercial "anti mist" products and do you think they'd help in such an extreme case of misting?
Is it going to be a nightmare job to move all the plastic guttering to check underneath and see if there's any more gunge?
With the current state of the wonderful British Summer, I think I really ought to get this sorted ASAP! I am going to email Vauxhall and see if they can/will help, so I'll post any useful response here for anyone else who may have this potentially lethal phenomenon.
Cheers all!
Cheers all!
