I have two ongoing problems with my van. An oil leak that stops and starts. It went away for 4 months and then came back. I have located it to be leaking down on to the water pump so must be coming from above somewhere. Any ideas?
Also I’m filling my van up with water after every long journey. I had a radiator replaced about 2 months ago but it was happening before that and no signs of water leakage. I did notice it bubbling out the expansion cap when finishing a journey once but is there not an overflow pipe on the tank for that? Also would a poorly fitted cap allow you to loose an entire expansion tank of water? The van never over heats so I’m sure it must drop to a certain level and then hold?
