{vauxhall mavano} i have had this van for about 4 months its a 2.5 on a 03 plate
in the last 3 weeks it has started to cut out when i start to go up the box its ok in 1st 2nd gears when i go in to 3 4 5 gears it shuts down ,if you turn the key off the on it starts its seems like a elec fault . i had it plugged in to a computer and it showed a fault of the fuel perisher switch on the rail phoned vauxhall they said the part is £160 but are not sure if that is the fault as the have not sold a lot of these and said that i should book the van in to them. does any one no if this is the fault or had the same problem
