vauxhall zafira 1.6 16v oil leaks
18 Oct 2005
Manchester
Can anyone tell me if they know of any common oil leaks appearing on vauxhall 1.6 engines it appears to be sump gasket ! but i want to check before dismantling.
thanks all
Not usually a common problem. Seen a few Ecotecs leak, but very rarely.
Sometimes what looks like a sump gasket can actually be from elsewhere
eg: front or rear crank seals, but not done many of these either.
cheers
CJ
ex-Vauxhall tech
cheers
CJ
ex-Vauxhall tech
thanks mate hoped it wasn't crankshaft seal but looks like front one
How many miles has your Zafira done?
If it's either around 40k or 80k you'll be changing the T Belt anyway, so much easier to do a front crank then as the belt is off anyway.
cheers
CJ
