Vaxhall Frontera Battery Drain Problem
11 Nov 2009
Pembrokeshire
My frontera 2.3 1993 is suffering a slow drain from the battery. I have individually removed each fuse to try to isolate the problem item. I know it is through the 60A fuse in the engine compartment but cannot find out which parts are fed from this? Can you please help!
Have a look at the Tranny battery post...a 60 amp fuse is obviously one of the main supply / charging ones so you may get some ideas from there. John :)
