- Joined
- 17 Apr 2006
- Messages
- 53
- Reaction score
- 0
- Country
Hi all,
Was trying to sort out a freinds heating system today, shes just moved into an older house. VCW 242 boiler running 6 rads.
They were getting various probs, (lots of leaks on the rads) so sorted up as much as I could.
After having drined the system/relived pressure more like, to repair the leaks on the rads, i filled the system back up to 1.5bar and ran the boiler.
Could hear it sparking then going to lock out without lighting.
After a little mucking about I discovered that if i knocked the black plastic section on front of the gas valve while it was sparking the flame would appear.
And a little later if i hit that part again it will go to high flame.
Im not too familair with these boilers as Im guilty of running away from them in the past when i see it working for more than 10 sec lol.
But I want to learn now, would a typical thought be that the venturi/tiny copper tipes from the pump to the plastic unit are possible blocked?
is there a diaghram inside that black section or something i can strip and clean to make it modulate/control the gas valve better.
Thanks Very much for any input possible.
