- Joined
- 1 Oct 2022
- Messages
- 1
- Reaction score
- 0
- Country
I have had Viessman Vitoden 200 for ~6 years. Have had almost no issues with it, works brilliantly. However the central heating has stopped working in the last couple of weeks. The boiler seems fine, no fault code, green light, hot water good etc. The only problem I can actually see is that the external weather temp sensor is always reading too high. I’ve checked the display screen on the boiler many times at different times of the day and night and the reading is always too high, between 22c and 30c outside. It’s on a north facing wall and has always been accurate in the past. So I assume the sensor has broken. Is that a fair assessment? Is this a common problem with this model? Is there any way I can reprogram the boiler to bypass or workaround the temp sensor? Any help or advice greatly appreciated. Thank you.
