Velux install from inside
3 Aug 2005
Surrey Hills
Is it standard to install a velux from the inside? The contractor is recommending a tower which is presumably adding significantly to the cost.
Supply and erect tower
Supply Velux MK04 roof window & flashing kit
Remove insulation and roof tiles, trim opening, alter insulation and reboard
Install roof window including roof tiling and installation of flashings
Supply tile fittings (eaves and gables)
Remove tower
I did two about 20 years ago from the inside, assume its still do-able?
Get some more quotes or go back to the builder for an explanation?
I did mine entirely from the inside, 25 years ago. Lift one tile up, bring it inside, rinse and repeat until enough tiles have been removed for window, plus a few. Cut and reinforce roof timbers, insert window, fix, then flashing. Finally reinstall tiles close up to flashing. Most difficult part, is lifting the window into place they can be heavy.
Roof tiles are nailed down , or should be .
If it makes a difference, my roof is a mid 1950's and despite being in a quiet exposed location, I have never had a tile come off.
