Hi
I've got a roofer turning up to replace an original 1910 "velux" with a new much larger version an also install a new one elsewhere in the roof. These are being installed in our "lean-to" roof/loft space over the rear of our victorian terrace house.
We also need to cut through the purlin as this is in the way - how is this best supported?
I think I have the basics as a result of looking at this forum (obviously make sure there is a v solid frame around the hole), however what are the key things to look out for to make sure this is done properly (no I decided not to go building regs.... ).
From the other posts I've seen, the joists either side of the new holes should be doubled up with the quantity of ones removed. Do these need to run the full length of the existing joist (very difficult to install as we have a ceiling in the way) and do the horizontal "ceiling support" joists also need to be braced in the same way?
Thanks for any assistance in advance
Russ
Russ
