Hi there folks,
I have just moved in to a new house and have found that in the nice new garage conversion there is a large hole about 4 inches in diameter, looks like it may have been for a tumble drier.
Now that the cold weather is beginning to set in its getting pretty cold in there. The wall is made up of plaster board with insulation behind it, a gap then the outside brick which on the outside is covered by a metal vent. The hole goes right through the plaster board, insulation and brick.
I was looking for advice on
A/ Should I be covering the hole inside/outside
B/ How I shoulld be covering/filling it
Thank you for any help.
