Hi all ,great forums
I'm replcaing an air vent in the outside front wall (used for fireplace ventilation). I'm fitting a black hole vent in replacement of the current standard air brick type...
Anyway, inside the current vent pathway is a stone duct. In order to fit the new bigger vent this brick will have to be removed and replaced with the plastic duct of the new vent (which is roughly the same width and height of the brick opening).
So, my question is , is this current stone duct section a supporting feature of any kind? its obviously cemented in between the breeze blocks..
or can i just remove it , widen the hole, and insert the plastic ducting?
Also, the plastic duct is slightly larger then the brick opening by about half an inch.. can i enlarge it on the brick side or is it too difficult a job without risking overwidening it or unsettling the surrounding brickwork?
