i have recently built a large extension on my house, to all intents and purposes, it is a separate house, but both houses are using a shared ch/dhw system.
originally in my house, i had a firebird 90 oil fired boiler. the pump was on the return leg, right next to the boiler, and pushed the water into the boiler. on the flow side of the boiler, there was a 1 inch pipe( in ireland its all 1/2 3/4 or 1 inch pipe). this 1 inch pipe teed into 2 3/4 inch pipes. the pipe that was on the c/h circuit had a zone valve on it, and the pipe for the dhw didnt have a zone valve.
because the firebird 90 wasnt big enough, i bought a firebird 90/120 boiler. i installed it to the pipework on the original house and all was fine. i moved the cylinder, including the vent pipe that goes to above the small tank in the loft.
about a month later, i connected the pipework from the new house to the boiler. i connected a second cylinder and a second set of radiators to the boiler. i also installed a second vent pipe from the cylinder to above the small tank in the original loft. there are now 2 vent pipes above the smaal header tank.
when i installed this pipework, i didnt put in any zone valves, but a couple of days ago, i put in 2 zone valves, one for the radiators and one for the dhw. when i close both of these valves, (ie no ch or dhw on in new house) and i still have the boiler running for the original house, scalding water is being pumped out of the vent pipe from the new cylinder into the small header tank. however if i just turn the radiator system in the new house off, it stops flowing out of the vent pipe.
is there something else i can use instead of a vent pipe, so that the dhw system is sealed rather than vented.
any help would be greatly appreciated
cheers
simon
cheers
simon
