I am installing a new downstairs WC and am wondering if I need a vent stack, or stink pipe, if ALL that I have on the drain is the toilet.
The sink is drained separately as it would have been awkward to tie it into the toilet waste.
There is a bedroom above the WC, so no additional drainage is required into the toilet waste from anywhere else in the house.
If I DO need a vent stack, then assuming there is no waste water ever flowing in it (above where the toilet waste enters it) then does it really need to be a 110mm pipe? As this pipe will only be used for an air inlet during flushing, or a vent for the sewer gas at other times, then can I change over to a 68mm vertical pipe, or for that matter 50, 40, 30 or 22mm.
thanks
thanks
