Some thoughts and advice please:
Having recently had some CH boiler problems, (now fixed), various engineers have suggested that I should consider an unvented, pressurised system.
I'd like to get some unbiased views on this please:
I currently have a free standing condensing boiler, thats vented and supplied by a tank in my attic. The system does suffer a bit from air, and in winter I've usually got to bleed a couple of the highest radiators twice a month. Not onerous, but a pain nevertheless.
When I had boiler problems, I did consider moving to a Combi boiler, however my experience with them, and in particular shower flow rates hasn't convinced me that is the way to go.
I'm considering moving to a fully pressurised system (via a qualified & certified engineer), by getting rid of the DHW and CH supply tanks in the attic, and also the copper HW tank, replacing it with a stainless steel pressurised storage tank with all the usual pressure regulating valves and expansion vessels etc. Which I'm told will fit in the cupboard where my current HW tank is.
Theory is, I can keep my existing, and relatively simple system condensing grade A boiler, and get cleaner, healthier & pressurised water from the stainless steel tank. Also, as the system is pressurised (and regulated) via the mains, it would hopefully eliminate having to bleed radiators so much.
Thoughts please?
Thoughts please?
