I'm running some cables to extend a ring main into my conservatory. I have an electrician coming in a few weeks to check things out and connect up the ring and sockets. I'm provisionally fitting all the cables but leaving everything accessible just in case.
I originally put the cables in the cavity but with the insulation in there, the advise I got on here was that the circuit would need to be down rated, etc.
I've now taken the cables out of the cavity and was going to lay them along the rail which runs along the timber batons supporting the boarded wall. As these cables are within 150mm of the top of the 'wall' I thought this would okay as per the Regs. My only concern is that the cables are pretty much surrounded by the timber rail, plasterboard wall, windowboard, ply board supporting the windowboard, etc. There is a bit of a gap in this channel where air can escape down behind the stud wall but just wanted to check whether there are any problems with this solution.
I'd be very grateful of any views. The attached picture isn't that great but may help explain what I've tried to describe.
Many thanks,
Damian
Many thanks,
Damian
