Hi
We have a condensation problem in our end terraced house (old solid stone walls with no cavity).
We have had two damp surveys done both of which found that there was no damp in the walls (the wall was rendered externally about 5 years ago). So it seems it is likely that the wall is suffering due to the amount of condensation with it being a cold wall etc.
Will installing louvre vents help sort this out? If so where should we install them? There are no airbricks I can see at the bottom of the house and the only ventilation we have is extractor fans in the kitchen and bathroom downstairs and trickle vents on the windows upstairs.
The problem is particularly bad under the stairs and along the downstairs external wall in the living room.
Just to sound even more like a true novice if we do install louvre vents is it a case of drilling holes and knocking them through to fit an aluminium ducting then screwing the vent plates on either side of the wall?
Sorry for all the questions and for probably sounding like an idiot but please be kind I'm new and at the end of my tether!
