S
Simonbeasley1
Started to install an ensuite for a client. I noticed a lot of vents on internal doors ceilings/walls etc and thought Hot AIR. I had a look in the cupboard upderstairs and found a
Johnson & Starley HI-SPEC J25 WARM AIR HEATER with circulator.
The door was just full of vents top and bottom.
I had a look on the outside of the house and i could not see any external vents apart from one of those that sit in a pain of glass and rotates with a cord to open & close. The door between this external vent and boiler has a 6" in the bottom corner.
I would have thought it would need to be vented top & bottom from an external wall. Any walls in between to then have 50% bigger vents top and bottom again.
Shoul this have an external vents???
http://www.johnsonandstarley.co.uk/downloads/ZZ0753.pdf
regards
Simon
[/b]
regards
Simon
[/b]
