Ventilation tubing throught flat roof space
9 May 2007
Does anyone know a good way to push a 4m lenght of flexiable ventilation tubing throught a flat roof space please. The tubing is 15cm, in diameter, and the roof space is 15cm ! Ahhh..... please help, I was thinking to cut a hole on the ceiling, where the tube will eventually come out, and push the tube in from this end, and attach maybe a piece of string and have a friend gently pull it from the other end, but my fear is that the tube may rip open.
Need to know what type of roof material, am'I right saying in New Zealand you may have a metal sheeting roof type?
I don't know what your flexible tubing is design for but I would think you would need a stainless flue pipe which you can connect the flexible to, then use roof flashing as below(?)
