Hi guys,
I currently have the following pitched roof construction, mono pitched lean to roof, marley modern tiles, 50x38 battens, cromar vent 3 light membrane, 50mm air gap, 100mm cellotex, 50mmc cellotex over rafters taped, vcl membrane, 12.5mm plasterboard, there are no vents in the roof. this was installed on a new extension.
We are getting a lot of condensation on the underside of the felt which is dripping down at the lowest point.
The builder is planning to install over facia ventilator and vent tiles further up the roof, I am concerned as he wants to vent the 50mm airgap where as my research suggests that the ventilation should be to the top of the membrane and essentially, not in the 50mm void which is effectively inside the building.
would appreciate some advice
thanks
thanks
