- Joined
- 26 Oct 2020
- Messages
- 50
- Reaction score
- 0
- Country
Hi All,
A quick question which i hope has a straightforward answer.
We have a cold/open/vented loft. Air comes in via the soffits below the rafers at floor level. I've insulated the floor to recommended standards and boarded, being careful to leave adequate space around the edges so ventilation is not affected.
As above, the only ventilation is at floor level and in the summer an immense amount of heat gets trapped in the loft, which often takes a long time to dissipate. There are no issues with condensation that i can tell and the timbers that i can see look a bit dusty but generally OK. There is roofing felt battoned to the inside of the rafters which will need removing so i cant be positive that the overall condition is fine until this is removed and i can take a closer look.
Nevertheless, i'm sure that such extreme temperature changes, especially when humid or very dry, cannot be good long term for both the structure and my belongings stored in the loft so I would like to add some ventilation at a higher level to allow the hot air to escape.
In short, is this advisable?
I'd like to avoud venting the ridge as we have a character property, so i'm thinking more along the lines of tile vents at a higher level.
Thanks in advance! Razz.
