Hi
Property I bought has a fireplace in lounge and another in the bedroom with flues up to a chimney stack that has been dropped below roofline.
As far as I can tell the chimney is not ventilated at the top where it's been dropped. The fireplaces are still open so warm air from the house is going up the flues. I want to brick/board across the fireplaces to prevent heat loss, but I understand ventilation is required?
I'd prefer not to fit airbricks or plastic grills as heat and warm moist air will still escape up flues. Would drilling 3-4 holes (approx 12mm diameter) in the exterior wall through to the flue be ok to allow outside air to pass through into the flues to keep it all ventilated? I'd then fit louvre style grills with insect screen over the holes.
