Recently moved into a house with a septic tank and have a few issues with smells coming off it.
Tank is onion style and was emptied when we moved in 3 months ago.
The tank fills exremely quickly and appears to work okay with clear effluent visible in the drain field inspection chamber - gulley.
The tank has the old klargester diamond shaped cover with the main neck, inlet and outlet pipes visible in the cover frame.
The house is a bungalow approximately 30m long and AAV- Durgo valves are fitted on top of all soil pipes in the roof void, there is no atmospheric vent external to the house.
The below ground pipe travels 22m to the septic tank and there is no visible vent.
The smell comes and go's but seems to peek about every 4 weeks which usually coincides with a blockage in the tank end of the 22m long pipe.
I have a feeling that the problem is due to blocked sewer gasses blowing through the manhole lid.
How do i apply vents and how many, where, what size and what materials do i need?
