Moved into a property and noticed that the vent pipe from the CH circuit into the F&E tank in the loft is constantly running, even when the system starts up from cold.
I have replaced the old F&E tank as the orginal had a missing lid and replaced the circulating pump, as the old one was a seizing up now and again. (The vent pipe was constantly running into the old F&E tank before I changed it and the pump).
System is fully pumped indirect fed off an old valiant boiler.
I have made sure the new pump is in the correct direction of flow from the orignial one that was removed and it is set to the lowest speeed setting.
I Have flushed the system out as I had cold spots at the bottom of the radiators assuming this was sludge, yet i still seem to be getting overspill coming up the vent pipe into the F&E tank. Any ideas ???
