Posted 6 weeks ago regarding mains cold and low pressure hot feed for shower. Bought a Trevi Boost venturi shower and it looks good. Just installed it however and I am having problems getting any kind of temperature from the shower.
I understood that it would work with up to 3 bar mains pressure, mine is around 2.5 bar. I have increased the temperature of hot water to around 60 and slightly above.
The only time you get any heat through the system is when you throttle back the mains stop cock to a flow rate similar to the hot. In this case it only provides a dribble and is effectively working as a non thermostat mixer.
Am I missing something here? By throttling back the cold I am adjusting the inlet cold pressure which will affect the performance graphs.
I though I could leave the stopcock for the cold feed open and adjust the flow on the valve to get the right temperature.
Any views or any help, I dont want to scrap all the work done so far.
Also, fitted a shallow trap to the shower tray, slight leaks, should I use silicon sealant?
JA
JA
