ok here we go : Testing a final ring circuit today cross connecting phase and CPC to get R1+R2 value etc. The value recorded at the ring mid point (socket outlet) was 0.6ohms
Prior to the cross I did the intital check for continuity at the ends of the ring i.e phase OUT to phase IN neutral OUT to neutral IN and CPC OUT to CPC IN
phase OUT to phase IN measured: 0.1ohms
CPC OUT to CPC IN measured:0.17ohms
so the loop resistance was : 0.27ohms
My question is why is the (cross connected) socket outlet reading 0.6ohms when it should be 1/4 of the Phase + CPC loop resistance
My guess is a multiple loop (loop within a loop) cause by DIY over the years. Its defo not loose connections belive me I took all 13 sockets off and tightened the lot.
Cheers
Cheers
