Hi, can anybody help?
I have been doing some work at a residential property and was asked to replace some shock sensors on the window frames. After i had a look, it was obvious that the reason that they were all hanging loose was because the old wooden frames had been replaced by Upvc frames and the fitters chose to leave them off! They also had a lump of the wooden frame still attached, this, i presume was to stop them having to remove the cover and set the tamper off. Anyway, i took the bull by the horns and re-fitted them and all was well until i came to the front door which had a round recessed reed switch hanging, the mating part been carted off with the old door, and the back door which had magnetic long reed switch taped together with the magnet again hanging loose. What can i replace the recessed switch with as i cannot bore out the Upvc door and the long magnetic reed switch cannot be mounted in the correct position to enable the magnet to contact the switch! Can anybody please advise?
Many thanks,
Gary.
Many thanks,
Gary.
