I am trying to get a Veritas 8 alarm system to set. This system was installed by a previous owner.
When I enter my code, prior to pressing "Full", the zone 1 light is on and the unset light flashes.
If I then press "Full", the panel bleeps with one bleep probably about a second apart (maybe a bit less). It continues to do this and never arms.
When I press "omit" to attempt to arm without zone 1, all zones light up but zone 1 flashes. All zones can be disabled apart from zone 1, which gives a low pitched beep.
Zone 1 is, according to the sheet, the magnetic door contact on the door we use to enter/exit the house. I have tried setting with the door open and closed but there's no difference.
Can anyone suggest some steps to diagnose the problem?
