I've recently decorated my hallway.. During the process I unscrewed two PIRs (OPTEX EX-35T) from the walls - did not disconnect, just unscrewed, wiring is intact.
One PIR in the hallway - on Zone 2.
One PIR on the Landing - on Zone 7.
I had to power down the mains (including the Alarm system), to fit some plugs / light sockets.
Brought the power back up and now I am having issues setting the alarm.
I have two Part Sets
- 1 for all of downstairs (3 magnetic contacts, 3 PIRs)
- 1 for upstairs, just the one Landing PIR
When enter the code to set the alarm, zone 2 and zone 7 PIRs light up red, with the unset green led flashing.
If I then press 'full', the keypad repeatedly beeps seven times (for zone 2 and zone 7 PIR I guess).
Alternatively, if I press 'part' after entering the code, the key pad clicks (giving me time to vacate the zone, then starts repeatedly beeping two times (as if I have not left the zone).
If I let the beeping continue, the alarm does not go off..
It seems that the PIRS are constantly registered as open on the Keypad - If I observe the PIRs in situ, they flick on and off with movement as expected.
One other thing I've noticed.. the tamper alarm goes off if I remove the keypad cover or the main unit cover.. It does not seem to go off if I remove the PIR front cover (or press the tamper switch after removing the cover)
Note that I have two other PIR's that seem fine and the magnetic contacts on doors all seem fine..
Sorry for the long post. Any assistance appreciated.
Regards,
Dom
Regards,
Dom
