Veritas 8 Texecom alarm unresponsive to keypad inputs / unable to set alarm
8 Nov 2014
Yorkshire
Hi all,
I hope someone can point me in the correct direction with the issue I am having with my Veritas 8 Texecom alarm system with a remote LED only keypad.
Unfortunately, the information I have regarding the issue is a bit sketchy at the moment due to not having time to investigate as I am on 12hr shifts, but hopefully someone may have come across this issue before.
Upon returning home after a couple of days away, my wife entered the house and went to deactivate the alarm, the keypad beeped but did not reset the alarm, which then triggered the sounder.
I tried also to reset the alarm with the keypad, but it did not seem to reset although it was beeping when the keys were pressed (they are also lit).
If I remember correctly, the 8 red LEDs were not active on the keypad display (which makes me believe the main unit may be at fault ).
Eventually, as a last resort I cut the power to the alarm, which unfortunately is on the same circuit as the downstairs sockets, I then switched the power back onto the socket circuit and the alarm sounder came back on.
Eventually by turning the socket circuit on and off I think I managed to reset the sounder.
Unfortunately, due to the location of the mains MCB unit I could not see which LEDs (if any) were illuminating as I turned the power on and off.
As far as I am aware the rechargeable battery in the mains alarm unit has never been changed, (although I changed the alarm sounder box battery several years ago).
I am leaning towards the rechargeable battery possibly being the issue. but if anyone could advise me on any steps, I could take to narrow down the issue, I would be very grateful.
I intend to hopefully look at the issue when I next have a day off.
Many thanks in advance for any assistance given.
Glenn
Panel back up battery sounds most likely.
No power to panel external beep should ring for 15 minutes and then stop (modern bell boxes).
With no battery but mains power panel can behave contrary to expectations.
A rough guide is main panel battery replace every 5 years.
Hi secureiam, thank you for your response. I hope that is the case. I will certainly check it out as soon as I can.
Thanks once again
Glenn
