Veritas 8 - texecom - PIR power question
18 Feb 2013
Birmingham
Hi all,
I know this is a dump question and please forgive me as I've not wired a burglar alarm for ages.
This is a veritable 8 texecom alarm.
I have 6 PIR's all on separate zones (a single cable runs to each PIR)
In the board there is only 1 + and 1 - terminal for all 6 PIR's.
Do I just put all 6 white cables (the colour being used for the +) into a connector block and run a cable from connector to the + terminal therefore powering all 6. Also do the same for the -
Or do I wire them the same way as the global tamper.
I'm presuming its the connector block way as each PIR just needs power and is controlled from the zone wires?
I appreciate any help, thanks.
All 6 should fit in the + terminal, but you can put them in a terminal block and take a single out of this if it's easier.
