hello one and all, i have recenly bought a house with my girlfriend and the house has a Texecom Veritas 8Compact alarm fitted. all has been well with it until yesterday....
it wouldnt set last night an everytime you pressed a button on the panal it would do a different "beep" than it had done previously and the "unset" light would flash.
i have looked through google a bit and there were loads of posts to say change the battery etc. i have done this (maplin £35) but its exactly the same. on the posts that i found it says to:
turn mains off to alarm
open panel
disconnect battery
check fuses
turn mains back on
press the spring switch 3 times each time it will beep each time
reconnect battery
enter code on alarm panel
replace cover on alarm...jobs a good un
However......when i press the spring switch the alarm is off, dead to the world! it only gets life back into it when the battery is reconnected is this normal?
i have left my voltmeter in work i will check it tommorow, does that sound normal or do you think the transformer/ psu has gone?
cheers
sorry for the long post
open panel
disconnect battery
check fuses
turn mains back on
reconnect battery
cheers
