Veritas R8 alarm set without pin
16 Sep 2010
Merseyside
hello all we recently bought a house with a Veritas alarm installed
been reading throught he user guide an it mentions that you enter the "pin" to set the alarm, on our alarm you can just press "set" an it will arm
is that ok??
also i have tried to reset the pin (the code you put in to deactivate the alarm) by:
enter existing code
Prog
60
enter new code
Prog
Reset
but the pin doesnt seem to change
anyone help?
thanks!
Could be the earlier version.
Try this.
Enter existing code.
Enter 00
Enter 01
Enter new code
Press Prog
Press Reset
Hi thanks for the reply all sorted. i reset the alarm using the button thingy 3 times
i can now change the code using Program 60
thanks
Hi, Single button set (As you describe), can be enabled as part of the engineers programming suite. It saves typing you PIN in every time you leave but can be a pain if you have kids with curious fingers. It can be enabled / disabled from within the programming menu.
Hope the info helps.
Regards,
Nat.
